Community Member
Addressing for interface with NAT
I've got a quick one... On a PIX, does NAT require one of the interfaces to to have an IP with the subnet of the global address?
For example... If 5.5.5.0/24 is my global nat, will this require one of my interfaces to be configured with the 5.5.5/24 subnet?
Thanks!
1 ACCEPTED SOLUTION
Re: Addressing for interface with NAT
No, but it should be routable. This means that you need to have an inside router that handles the routing and you have configured an inside route to that router.
example:
ip address inside 1.1.1.1 255.255.255.0
nat (inside) 1 5.5.5.0 255.255.255.0
nat (inside) 1 1.1.1.0 255.255.255.0
route inside 5.5.5.0 255.255.255.0 1.1.1.2
route outside 0.0.0.0 0.0.0.0 RouterPubIP
sincerely
Patrick
1 REPLY
example:
sincerely
Patrick
99
