ADM(Anomaly Dectector Module) PowerDown Failure in upgrade process.
hellow, everyone.
i'm yunchouljung in korea
i have a question about ADM module power down issue.
i had upgraded AGM Module successfully in version 6.1.2 to 6.1.6
but failed ADM Module upgrade in version 6.1.2 to 6.1.6
i uploaded a AP images in MP status and enterd "hw-module module 12 reset cf:4" command.
(i waited a message "you can now reset the module....")
after a reset process, ADM module disabled by SCP dnld Failure.
so, i enabled a power on ADM Module but result is same.
my upgrade process is below.
1.     hw-module module 12 reset cf:1
2.     copy ftp://anonymous@x.x.x.x/c6svc-adm1G-k9.6-1-6.bin pclc#12-fs:
3.     hw-module module 12 reset cf:4
anybody help me?
thanks in advance.
p.s : i have already tested other ios version and ap/mp images.
the module version and log is below.
Router_OUT#sh module
Mod Ports Card Type                              Model              Serial No.
  2    3  Anomaly Guard Module                   WS-SVC-AGM-1-K9
  3   16  16 port 1000mb GBIC ethernet           WS-X6416-GBIC
  5   48  SFM-capable 48 port 10/100/1000mb RJ45 WS-X6548-GE-TX
  7    2  Supervisor Engine 720 (Active)         WS-SUP720-3B
  9    4  CEF720 4 port 10-Gigabit Ethernet      WS-X6704-10GE
10    8  Network Analysis Module                WS-SVC-NAM-2
12    3  Anomaly Detector Module                WS-SVC-ADM-1-K9
Mod MAC addresses                       Hw    Fw           Sw           Status
  2  0017.e067.ec6c to 0017.e067.ec73   2.0   7.2(1)       6.1(6)       Ok
  3  000e.d73c.3d40 to 000e.d73c.3d4f   2.5   5.4(2)       8.5(0.46)RFW Ok
  5  0015.2bfe.c130 to 0015.2bfe.c15f  10.1   7.2(1)       8.5(0.46)RFW Ok
  7  0016.c85e.3aa0 to 0016.c85e.3aa3   5.2   8.4(2)       12.2(18)SXF1 Ok
  9  001b.d45d.f890 to 001b.d45d.f893   2.6   12.2(14r)S5  12.2(18)SXF1 Ok
10  0003.fead.7592 to 0003.fead.7599   2.0   7.2(1)       4.0(1)       Ok
12  0012.80f1.1ae8 to 0012.80f1.1aef   1.0   7.2(1)       8.5(0.46)RFW PwrDown
Mod  Sub-Module                  Model              Serial       Hw     Status
  7  Policy Feature Card 3       WS-F6K-PFC3B       SAL10478K1R  2.3    Ok
  7  MSFC3 Daughterboard         WS-SUP720          SAL104892TJ  2.5    Ok
  9  Centralized Forwarding Card WS-F6700-CFC       SAL1124QX44  3.1    Ok
Mod  Online Diag Status
  2  Pass
  3  Pass
  5  Pass
  7  Pass
  9  Pass
10  Pass
12  Not Applicable
Router_OUT#
47w1d: SP: The PC in slot 2 is shutting down. Please wait ...
47w1d: SP: shutdown_pc_process:No response from module 2
Jul 13 16:54:49: %C6KPWR-SP-4-DISABLED: power to module in slot 2 set off (Reset)
47w1d: SP: OS_BOOT_STATUS(2) MP OS Boot Status: finished booting
Jul 13 16:56:50: %DIAG-SP-6-RUN_MINIMUM: Module 2: Running Minimal Diagnostics...
Jul 13 16:56:57: %MLS_RATE-4-DISABLING: The Layer2 Rate Limiters have been disabled.
Jul 13 16:56:57: %DIAG-SP-6-DIAG_OK: Module 2: Passed Online Diagnostics
Jul 13 16:56:57: %OIR-SP-6-INSCARD: Card inserted in slot 2, interfaces are now online
Jul 13 16:56:58: %SVCLC-5-FWTRUNK: Firewalled VLANs configured on trunks
Jul 13 17:32:23: %SVCLC-SP-5-STRRECVD: mod 2: <Application upgrade has started>
Jul 13 17:32:23: %SVCLC-SP-5-STRRECVD: mod 2: <Do not reset the module till upgrade completes!!>
Jul 13 17:42:11: %SVCLC-SP-5-STRRECVD: mod 2: <Application upgrade has succeeded>
Jul 13 17:42:11: %SVCLC-SP-5-STRRECVD: mod 2: <You can now reset the module>
47w1d: SP: PC shutdown completed for module 2
Jul 13 17:42:57: %C6KPWR-SP-4-DISABLED: power to module in slot 2 set off (Reset)
47w1d: SP: OS_BOOT_STATUS(2) Anomaly Guard OS Boot Status: finished booting
Jul 13 17:45:03: %DIAG-SP-6-RUN_MINIMUM: Module 2: Running Minimal Diagnostics...
Jul 13 17:45:06: %MLS_RATE-4-DISABLING: The Layer2 Rate Limiters have been disabled.
Jul 13 17:45:06: %DIAG-SP-6-DIAG_OK: Module 2: Passed Online Diagnostics
Jul 13 17:45:06: %OIR-SP-6-INSCARD: Card inserted in slot 2, interfaces are now online
Jul 13 17:45:07: %SVCLC-5-FWTRUNK: Firewalled VLANs configured on trunks
47w1d: SP: The PC in slot 12 is shutting down. Please wait ...
47w1d: SP: shutdown_pc_process:No response from module 12
Jul 13 17:53:29: %C6KPWR-SP-4-DISABLED: power to module in slot 12 set off (Reset)
47w1d: SP: OS_BOOT_STATUS(12) MP OS Boot Status: finished booting
Jul 13 17:55:30: %DIAG-SP-6-RUN_MINIMUM: Module 12: Running Minimal Diagnostics...
Jul 13 17:55:37: %MLS_RATE-4-DISABLING: The Layer2 Rate Limiters have been disabled.
Jul 13 17:55:36: %DIAG-SP-6-DIAG_OK: Module 12: Passed Online Diagnostics
Jul 13 17:55:37: %OIR-SP-6-INSCARD: Card inserted in slot 12, interfaces are now online
Jul 13 18:26:27: %SVCLC-SP-5-STRRECVD: mod 12: <Application upgrade has started>
Jul 13 18:26:27: %SVCLC-SP-5-STRRECVD: mod 12: <Do not reset the module till upgrade completes!!>
Jul 13 18:37:05: %SVCLC-SP-5-STRRECVD: mod 12: <Application upgrade has succeeded>
Jul 13 18:37:05: %SVCLC-SP-5-STRRECVD: mod 12: <You can now reset the module>
47w1d: SP: PC shutdown completed for module 12
Jul 13 18:38:35: %C6KPWR-SP-4-DISABLED: power to module in slot 12 set off (Reset)
Jul 13 18:46:04: %C6KPWR-SP-4-DISABLED: power to module in slot 12 set off (Module  Failed SCP dnld)
Jul 13 18:53:54: %OIR-SP-6-REMCARD: Card removed from slot 12, interfaces disabled
Jul 13 19:01:28: %C6KPWR-SP-4-DISABLED: power to module in slot 12 set off (Module  Failed SCP dnld)
Everyone's tags (1)
873
