AES-256 with VPN Client und ASA 5520
How do I setup AES-256 encryption with a remote access-scenario AND easy vpn remote clients !
It always connects with 3DES. I am using client version 4.8.
cheers
Yves
Gold
Re: AES-256 with VPN Client und ASA 5520
I think you need change policy on router:
isakmp policy 1 encryption aes
(change policy number 1 to you policy number)
Also change your trasform set to esp-aes
crypto ipsec transform-set mySET esp-aes esp-sha-hmac
(again change rasforset name mySET to your transform set number)
M.
Hope that helps, rate if it does
My transform set explicitly say " please use AES 256 bit", .... but the Client does not.
Does it only work with VPN Concentrator 3000 and not with ASA ? But that seems odd to me .
Any ideas ?
Ok, ... no ideas. :-(
Is anyone of you guys running the EASY VPN Remote Client Setup with a ASA5520 and is using 256 bit-AES encryption ?
Yves
454
