After upgdate pix535 os ,pix Ignoring PCI card in slot 4
pix ignoring two pci card ,why ??
show ver list below :
Serial Number: 405300167 (0x182863c7)
Activation Key: 5f6dcede db39a37e bdd89444 a1142d0e
Do you want to enter a new activation key? [n]n
Writing 2494520 bytes image into flash...
1024MB RAM
Ignoring PCI card in slot:4 (vendor:0x8086 deviceid:0x1229 revisionid:0xc)
Ignoring PCI card in slot:5 (vendor:0x8086 deviceid:0x1229 revisionid:0xc)
Flash=i28F640J5 @ 0x300
BIOS Flash=DA28F320J5 @ 0xD8000
c i s c o S y s t e m s
Private Internet eXchange
Cisco PIX Firewall
Cisco PIX Firewall Version 6.1(4)
Licensed Features:
Failover: Enabled
VPN-DES: Enabled
VPN-3DES: Disabled
Maximum Interfaces: 10
Cut-through Proxy: Enabled
Guards: Enabled
Websense: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
ISAKMP peers: Unlimited
Not enough supported network interface cards installed.
PIX requires at least 2 supported interface cards,
but only 0 supported interfaces were fou
  • Other Security Subjects
Re: After upgdate pix535 os ,pix Ignoring PCI card in slot 4
Hi there,
You will get more specific information from the console during boot. Try to capture that output and see if it gives you more specific information. Otherwise, you will need to look at what the cards are and perhaps what changes there may have been in the new release by looking at the release note to determine support ofr the cards. Let us know if this does not give you the answers...
Marcus
HI, perhaps I have foud the problem,that i82550 Ethernet controller chip cann't
work well on pix firewall,please visit bleow address,and check it is true or not,i would report this prolem to my customer.thanks!
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_field_notice09186a0080094509.shtml
I would say that this is the issue you are having if you do have the i82550 inteface card. As the advisory states, you will have to have the cards swapped directly from the TAC.
Marcus
202
