Aladdin eToken and Cisco ASA 5500 integration
Dear all,
I am looking for PKI solution using Aladdin eToken incorporated with Cisco by authenticating ysers against Cisco ASA using PKI (certificate) stored on the eToken. Can anyone assist me how to do it? Below is my info:
Cisco ASA 5520.
ASDM version: 6.3.1
ASA version: 8.2.2
Cisco VPN client 5.0.04.0300
regards
Wesley
Everyone's tags (2)
1 REPLY
Re: Aladdin eToken and Cisco ASA 5500 integration
Hi Wesley,
I was going through the old unanswered posts and found this one - do you still need help with this?
If so, I recommend following (part of) the following document:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00809a3fa5.shtml
This is written for the US military's CAC smartcards, but the principle is the same. You can probably skip the LDAP part (unless you want to do LDAP authorization as well) and of course you will have to import your own enterprise CA certificate(s) .
I hope this helps, let me know.
Herbert
(BTW for future reference, the VPN category would probably be a better place to put this kind of question)
1830
