Alias to reach a dmz server - Help!
Hi all.
My Customer has a Pix with many public servers on the inside network. They use the alias command to do DNS Doctoring and access the servers from the inside using their domain name. The inside network has a private address and the configuration works fine.
Now they're planning to move the servers to the DMZ and still want to be able to reference the servers with their domain name, but I have problems implementing the alias command as illustrated in http://www.cisco.com/warp/public/110/alias.html
Neither DNS doctoring nor Destination Nat work and when I deploy the alias command the customer say they cannot even access the server using its private address!!!
First of all: should I use DNS doctoring (i.e. alias (inside) 192.168.199.100 A.B.C.100 255.255.255.255) or Destination Nat (i.e. alias (inside) A.B.C.100 192.168.199.100 255.255.255.255) ?
Is there any other option I should enable (e.g. sysopt nodnsalias)?
Please find my config attached. It does not contain the alias for the dmz server, but the Customer is able to access the server using the private address.
Thank you very much for you help!
pix# wr t
Building configuration...
: Saved
PIX Version 5.1(5)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security50
enable password ************** encrypted
passwd ************** encrypted
hostname pix
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sqlnet 1521
no fixup protocol smtp 25
no names
access-list nonat permit ip any 192.168.210.0 255.255.255.0
access-list nonat permit ip any host A.B.C.100
access-list dmz permit icmp any any
pager lines 40
logging on
logging timestamp
no logging standby
no logging console
no logging monitor
logging buffered debugging
logging trap debugging
logging history debugging
logging facility 18
logging queue 512
no logging message 106014
no logging message 106006
no logging message 305003
no logging message 305002
no logging message 303002
no logging message 302002
no logging message 304001
no logging message 302001
no logging message 302006
no logging message 302005
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside A.B.C.126 255.255.255.128
ip address inside 192.168.204.1 255.255.255.0
ip address dmz 192.168.210.3 255.255.255.0
ip verify reverse-path interface outside
no failover
failover timeout 0:00:00
failover ip address outside 0.0.0.0
failover ip address inside 0.0.0.0
failover ip address dmz 0.0.0.0
arp timeout 14400
global (outside) 1 A.B.C.124 netmask 255.255.255.128
nat (inside) 0 access-list nonat
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
nat (dmz) 1 0.0.0.0 0.0.0.0 0 0
alias (inside) 192.168.204.40 A.B.C.40 255.255.255.255
!<many more aliases for the internal servers>
static (inside,outside) A.B.C.7 192.168.204.7 netmask 255.255.255.255 0 0
!< many more static (inside,outside)>
static (dmz,outside) A.B.C.100 192.168.210.100 netmask 255.255.255.255 0 0
access-group dmz in interface dmz
conduit permit tcp host A.B.C.11 eq smtp any
!<many more conduit statements>
outbound 10 permit 192.168.199.99 255.255.255.255 4444 tcp
!<many more outbound statements>
apply (inside) 10 outgoing_src
rip outside passive version 1
rip outside default version 1
rip inside passive version 1
rip inside default version 1
rip dmz passive version 1
rip dmz default version 1
route outside 0.0.0.0 0.0.0.0 A.B.C.125 1
timeout xlate 0:05:00 conn 0:05:00 half-closed 0:10:00 udp 0:02:00
timeout rpc 0:05:00 h323 0:05:00
timeout uauth 0:02:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
no snmp-server location
no snmp-server contact
snmp-server community public
snmp-server enable traps
floodguard enable
sysopt security fragguard
sysopt connection enforcesubnet
sysopt connection permit-ipsec
sysopt ipsec pl-compatible
no sysopt route dnat
service resetinbound
isakmp identity hostname
telnet 192.168.195.251 255.255.255.255 inside
telnet 192.168.195.252 255.255.255.255 inside
telnet 192.168.205.253 255.255.255.255 inside
telnet 192.168.205.254 255.255.255.255 inside
telnet timeout 5
terminal width 80
: end
[OK]
pix#
  • Other Security Subjects
Re: Alias to reach a dmz server - Help!
If the WWW server is on the DMZ, then you should use Destination NAT. This way the clients will try and connect to the actual global address of the server, and the PIX will intercept this as the packet goes out and change the destination to the address on the DMZ interface. You need to make sure you remove the alias command that does the DNS Doctoring though, don't have both otherwise you'll get strange things happening.
The comand you probably want is as follows:
> alias (inside) A.B.C.40 192.168.204.40 255.255.255.255
but make sure you remove the:
command first.
Glenn, Thank you very much for your tip!
Managed to implement Destination Nat, but only using the global (dmz) command. My first intent was not to use nat between the inside and the DMZ but this did not work if the alias was configured. I'm not sure why.
Here's my current (working) config:
global (dmz) 1 192.168.210.4 netmask 255.255.255.0
alias (inside) A.B.C.100 192.168.210.100 255.255.255.255
Well, I have another problem now.
The Customer is happy to access the dmz web server using the domain name, but still wants to manage it (Terminal Services) using its *private* address, as they used to do when the server was in the inside. They say they cannot do this. Is this an expected behaviour?
Thank you
95
