Allowing inbound www connections through cisco pix
This is really driving me nuts - I have scoured the internet for suggestions, and actually found several people who have had the same problem and got a solution that works. Doesnt seem to work for me though! I am trying to allow any external IP address access to a web server residing behind the firewall.
Since it seems to be a fairly common thing, I will post my current configuration.
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password ******** encrypted
passwd ********* encrypted
hostname phoenix
domain-name ciscopix.com
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
access-list outside_access_in permit icmp any any echo-reply
access-list outside_access_in permit icmp any any unreachable
access-list outside_access_in permit icmp any any time-exceeded
access-list outside_access_in permit tcp any any eq www
pager lines 24
logging on
logging timestamp
logging trap warnings
logging host inside 192.168.252.86
icmp permit any inside
mtu outside 1500
mtu inside 1500
ip address outside 213.254.xxx.xxx 255.255.255.240
ip address inside 192.168.252.41 255.255.255.0
ip verify reverse-path interface inside
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.252.69 255.255.255.255 inside
pdm location 0.0.0.0 255.255.255.255 inside
pdm location 0.0.0.0 255.255.255.255 outside
pdm location 192.168.252.71 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp interface www 192.168.252.71 www netmask 255.255.255.255 0 0
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 213.254.xxx.xxx 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.252.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet 192.168.252.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.252.42-192.168.252.169 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
terminal width 80
Cryptochecksum:xxxxxxxxx
Any advide would be hugely appreciated!
1 ACCEPTED SOLUTION
Re: Allowing inbound www connections through cisco pix
These log messages mean that we never saw a SYN-ACK from the server come back to the PIX so we tore the "half-open" connection down based on your timeout settings. Suggestions:
1) Make sure the WWW daemon on your server is started and terminating TCP/80 connections. Are you able to access this server from inside the PIX?
2) Make sure the default gateway on the server is pointed to the inside IP address of the PIX.
Scott
Gold
Hi -
Have a read of the following document and see if this helps you out, let me know how you get on.
http://www.cisco.com/warp/public/707/28.html
Thanks - Jay.
That was actually one of the sites that I had uncovered in my google searches - from what I understand from that, all I should need to allow outside access to a webserver inside it the lines:
Which (i think) allows tcp traffic from any untrusted source on the outside interface on port 80
Which should perform the forwarding from the outside interface to the web server (192.168.252.71)
Gold
Hello Ben,
Your static looks good but you need a ACL also to allow the outside traffic in i.e.
> static(inside,outside)tcp www 192.168.252.71 www netmask 255.255.255.255 0 0
> access-list outside permit tcp any host 192.168.252.71 eq www
> access-group outside in interface outside
Now, do command 'clear xlate' and save with command 'write memory'
Hope this helps -
I added this, but no luck... On thinking about it is that not covered by the original static anyway?
Besides - Recently discovered that the PIX is actually working the route out correctly (covered elsewhere in this conversation), however it terminates the TCP connection 2 mins and 1 second later with a SYN timeout.
Did you figure this out?? I am having the same problem!!
Not quite yet - but check your logs to see if the connection is being established at all? Looks like mine is, but then gets a SYN timeout after 2 mins before dropping the connection.
Adding this to your pix conf might solve this pblm:
route inside 192.168.252.0 255.255.255.0 192.168.x.x 1
Where 192.168.x.x is the gateway facing your FW.
If it doesn't work can you post a sample of syslog's when outside user try to reach the web server.
Mike
I tried adding this route - but apparently I already have it and its not making any difference. Interestingly on making the previous changes that have been suggested, there does seem to be some form of connection going on. The Informational syslogs show the following.
609001: Built local-host inside:192.168.252.71
305011: Built static TCP translation from inside:192.168.252.71/80 to outside:213.254.xxx.xxx/80
302013: Built inbound TCP connection 22018 for outside:69.56.xxx.xxx/51177 (69.56.xxx.xxx/51177) to inside:192.168.252.71/80 (213.254.xxx.xxx/80)
Which suggests (to me) that the connection has been made. However examining my apache logs show no sign of any connection attempt - which further suggests that I am still missing an ACL to actually allow the data through (?).
2 mins and 1 second after this I get:
302014: Teardown TCP connection 22018 for outside:69.56.xxx.xxx/51177 to inside:192.168.252.71/80 duration 0:02:01 bytes 0 SYN Timeout
... Actually I think I might have just worked it out myself! Perhaps I need to allow the ACK from 192.168.252.71 back out...
... Or maybe not. SYN/ACK is part of TCP and thats fully enabled from inside to outside due to the security level being less.
Damn.
Gold
Jay,
Thanks for your help on this! Learned a lot from your suggestions.
Scott
Aha! I was running the pix along side our temporary software firewall while I got it set up. So the gateway on the web server was not set to the pix, but to the software one.
Made the change, and all is well! Thanks!
Is your web server using http or https?
It has been observed on pix code 6.3.1 that after removing an existing static, and doing clear xlate clear local-host, a host on the outside is still able to access the host on the inside for which the previously removed static was for.
The Bug ID for this problem is CSCea84806
It is fixed in the new PIX 6.3.2
142
