An issue with authentication and authorization on ISE 1.2
Hi, I'm new to ISE.
I have an issue with authentication and authorization.
I have ISE 1.2 plus patch 6 installed on VMware.
I have built-in Windows XP supplicant and 2960 cisco switch with IOS c2960-lanbasek9-mz.150-2.SE5.bin
On supplicant I use EAP(PEAP) with EAP-MSCHAP v2.
I created  authentication and authorization rules with Active Directory  as External Identity Source. Also I applied  authorization profile with DACL.I login on Windows XP machine under different Active Directory accounts. Everything works fine (authentication, authorization ), but only for several hours. After several hours passed , authentication and authorization stop working . I can see that ISE trying authenticate and authorize users, but ISE always use only one account for  authentication and authorization . Even if I login under different accounts ISE continue to use only one last account.
I traied to reboot switch and PC,but it didn’t help. Only rebooting of ISE helps. After ISE rebooting, authentication and authorization start to work properly for several hours.
I don’t understand is it a glitch or I misconfigured ISE or switch, supplicant?
What  should I do to resolve this issue?
Switch configuration:
 testISE#sh runn
Building configuration...
Current configuration : 7103 bytes
! Last configuration change at 12:20:15Tue Apr 15 2014
! NVRAM config last updated at 10:35:02  Tue Apr 15 2014
version 15.0
no service pad
hostname testISE
boot-start-marker
boot-end-marker
no logging console
logging monitor informational
enable secret 5 ************
enable password ********
username radius-test password 0 ********
username admin privilege 15 secret 5 ******************
aaa new-model
aaa authentication dot1x default group radius
aaa authorization network default group radius
aaa authorization auth-proxy default group radius
aaa accounting update periodic 5
aaa accounting dot1x default start-stop group radius
aaa server radius dynamic-author
 client 172.16.0.90 server-key ********
aaa session-id common
clock timezone 4 0
system mtu routing 1500
authentication mac-move permit
ip dhcp snooping vlan 1,22
ip dhcp snooping
ip domain-name elauloks
ip device tracking probe use-svi
ip device tracking
epm logging
crypto pki trustpoint TP-self-signed-1888913408
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1888913408
 revocation-check none
 rsakeypair TP-self-signed-1888913408
crypto pki certificate chain TP-self-signed-1888913408
dot1x system-auth-control
spanning-tree mode pvst
vlan internal allocation policy ascending
ip ssh version 2
interface FastEthernet0/5
 switchport mode access
 ip access-group ACL-ALLOW in
 authentication event fail action next-method
 authentication event server dead action reinitialize vlan 1
 authentication event server alive action reinitialize
 authentication host-mode multi-auth
 authentication open
 authentication order dot1x mab
 authentication priority dot1x mab
 authentication port-control auto
 authentication periodic
 authentication timer reauthenticate server
 authentication violation restrict
 mab
 dot1x pae authenticator
 dot1x timeout tx-period 10
 spanning-tree portfast
interface FastEthernet0/6
 mab
interface FastEthernet0/7
interface Vlan1
 ip address 172.16.0.204 255.255.240.0
 no ip route-cache
ip default-gateway 172.16.0.1
ip http server
ip http secure-server
ip access-list extended ACL-ALLOW
 deny   icmp any host 172.16.0.1
 permit ip any any
ip radius source-interface Vlan1
logging origin-id ip
logging source-interface Vlan1
logging host 172.16.0.90 transport udp port 20514
snmp-server community public RO
snmp-server community ciscoro RO
snmp-server trap-source Vlan1
snmp-server source-interface informs Vlan1
snmp-server enable traps snmp linkdown linkup
snmp-server enable traps mac-notification change move
snmp-server host 172.16.0.90 ciscoro
radius-server attribute 6 on-for-login-auth
radius-server attribute 6 support-multiple
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius-server dead-criteria time 5 tries 3
radius-server vsa send accounting
radius-server vsa send authentication
radius server ISE-Alex
 address ipv4 172.16.0.90 auth-port 1812 acct-port 1813
 automate-tester username radius-test idle-time 15
 key ******
ntp server 172.16.0.1
ntp server 172.16.0.5
end
808
