12-31-2008 02:33 PM - edited 03-09-2019 09:55 PM
Dear all,
Is there any way to upgrade image for Anomaly Guard & Detector as I have tried the way mentioned in the documentation but its not working b/c new-version option in the command is not visible.
I have tried using following way but its not working...
admin@AD-2#copy ftp login-banner 172.16.250.10 /c6svc-adm1G-k9.6-1-5.
bin cisco cisco123
FTP in progress...
Error: Cannot import non-text banner file
admin@AD-2#
As per the documentation we need to use the following command but that is not available with any user
copy ftp new-version server full-file-name [login [password]]
Akhtar
01-06-2009 07:14 AM
For Upgrading the Guard Version
see the example in the following link:
http://www.cisco.com/en/US/products/ps5888/products_user_guide_chapter09186a00802d7252.htm
l#wp1077470
01-06-2009 10:00 AM
Link is not opening. Can you please check & provide the correct one.
03-08-2009 07:21 PM
Akhtar, Is this an Anomaly Guard/Detector Appliance or an Anomaly Guard/Detector Module?
Based upon the image you are trying to use I would guess the module. Unfortunately the modules do not follow the same upgrade documentation as the appliance.
To upgrade the module devices you must use the Maintenance Partition. See documentation here:
