Anomaly Guard & Anomaly Detector image upgradation
Dear all,
Is there any way to upgrade image for Anomaly Guard & Detector as I have tried the way mentioned in the documentation but its not working b/c new-version option in the command is not visible.
I have tried using following way but its not working...
admin@AD-2#copy ftp login-banner 172.16.250.10 /c6svc-adm1G-k9.6-1-5.
bin cisco cisco123
FTP in progress...
Error: Cannot import non-text banner file
admin@AD-2#
As per the documentation we need to use the following command but that is not available with any user
copy ftp new-version server full-file-name [login [password]]
Akhtar
Silver
Re: Anomaly Guard & Anomaly Detector image upgradation
For Upgrading the Guard Version
see the example in the following link:
http://www.cisco.com/en/US/products/ps5888/products_user_guide_chapter09186a00802d7252.htm
l#wp1077470
Link is not opening. Can you please check & provide the correct one.
Akhtar, Is this an Anomaly Guard/Detector Appliance or an Anomaly Guard/Detector Module?
Based upon the image you are trying to use I would guess the module. Unfortunately the modules do not follow the same upgrade documentation as the appliance.
To upgrade the module devices you must use the Maintenance Partition. See documentation here:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/anomaly_guard/v6.1/configuration/guide/mainten.html#wp1265062
285
