Community Member
Another 506 Question
You guys have helped so much I figured id ask another one!!
I have 2 506's at remote sites connected to DSL over PPPoE with a Static IP address. Can I create a VPN tunnel between them just like they were regular connections?
Is there anything special i have to do because they are PPPoE?
Thanks in advance,
1 REPLY
Silver
Re: Another 506 Question
I don't think so - static ips on both ends is ideal. pppoe should take effect at L2, and IPSec at L3, so their should not be any issues. I believe the tunnel will have a slightly lower MTU than most, due to the PPPOE overhead, but that should not present any problems
81
