Another Pix 501 Configuration issue
I just purchased a PIX 501 and thought I could get it configured without problemssince my set-up is simple. I also have experience with Linksys and Sonicwalls but since I'm in the big leagues now with Cisco, I'mbeing humbled.
I have a simple set up. 1 Static IP from my ISP that is PPPOE and on the inside I use a 192.168.1.x address. My workstation works fine and can access all I need outside but I'm not able to get smtp, pop3 & www trafic to my server from the outside. My serverIP is 192.168.1.11
The configuration file is below. Since I'm not very schooled on the CL, I have been using the PDM to create my configuration. If you could reference PDM in your reply, itwould really be helpful.
PIX Version 6.3(4)
interface ethernet0 100full
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxxx encrypted
passwd xxxxxxx encrypted
hostname pixfirewall
domain-name mydomain.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 192.168.1.11 mydomain.com
access-list outside_access_in permit tcp any eq www host mydomain.com eq www
access-list outside_access_in permit tcp any eq smtp host mydomain.com eq smtp
access-list outside_access_in permit tcp any eq pop3 host mydomain.com eq pop3
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside pppoe setroute
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location mydomain.com 255.255.255.255 inside
pdm location 209.xxx.xxx.xxx 255.255.255.255 outside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (outside,inside) tcp mydomain.com www 209.xxx.xxx.xxx www netmask 255.255.255.255 0 0
static (outside,inside) tcp mydomain.com smtp 209.xxx.xxx.xxx smtp netmask 255.255.255.255 0 0
static (outside,inside) tcp mydomain.com pop3 209.xxx.xxx.xxx pop3 netmask 255.255.255.255 0 0
static (inside,outside) mydomain.com mydomain.com dns netmask 255.255.255.255 0 0
access-group outside_access_in in interface outside
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn group pppoe_group request dialout pppoe
vpdn group pppoe_group localname allanmydomain
vpdn group pppoe_group ppp authentication pap
vpdn username allanmydomain password *********
dhcpd address 192.168.1.100-192.168.1.131 inside
dhcpd dns mydomain.com 209.242.0.2
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:xxxx
: end
[OK]
Thank you for any assistance,
Allan
Re: Another Pix 501 Configuration issue
The acces-list on the outside interface contain in the Destination the public IP and not the private IP !
The Static has also the wrong syntax
Change the setup to:
access-list outside_access_in permit tcp any interface outside eq www
access-list outside_access_in permit tcp any interface outside eq smtp
access-list outside_access_in permit tcp any interface outside eq pop3
static (inside,outside) tcp interface www 192.168.1.11 www netmask 255.255.255.255 0 0
static (inside,outside) tcp interface smtp 192.168.1.11 smtp netmask 255.255.255.255 0 0
static (inside,outside) tcp interface pop3 192.168.1.11 pop3 netmask 255.255.255.255 0 0
After that to a < clear xlate >
sincerely
Patrick
I didn't get it to work as you described. I added the following and now I'm able to get email and web traffic.
access-list outside_access_in permit tcp any any
The above opens up everything from what I can tell and obviously that isn't good.
I'm at least making headway and learning along the way.
Thanks for the help - without it I wouldn't have anything working.
Allan
Try again with:
# Figure out your Public IP (outside interface):
show ip
show interface
# Then add this lines but replace 'YourPubIP' by your Public IP:
access-list outside_access_in permit tcp any host YourPubIP eq www
access-list outside_access_in permit tcp any host YourPubIP eq smtp
access-list outside_access_in permit tcp any host YourPubIP eq pop3
no access-list outside_access_in permit tcp any any
clear xlate
sincely
Patrick
try adding this line
#route outside 0.0.0.0 0.0.0.0
renil
This worked too, Thank you!
hi allan,
pls do rate the post which helpd u..
thanx
renil
116
