Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Another Static question
Using a PIX 506e, I have an Exchange server, and use the static command to show it's public IP on outgoing connections. My static command looks like this:
static (inside,outside) x.x.x.x y.y.y.y netmask 255.255.255.255 0 0
Can I put any protocol attributes in? Currently all outgoing traffic is stamped with my Email's public IP address. I was thining of something like:
static (inside,outside) x.x.x.x smtp y.y.y.y smtp netmask 255.255.255.255 0 0
The reason i want to do this is beacuse my network setup is like:
LAN->ISA->PIX->Internet
All traffic coming out of the ISA server comes through the one NIC, and so has a single IP address.
Thanks in adavnce
HBalf1
Gold
Re: Another Static question
please excuse me for not fully understanding the requirement.
anyhow, the static statement you are after should be:
static (inside,outside) tcp x.x.x.x smtp y.y.y.y smtp netmask 255.255.255.255
with this static statement, of i should say port forwarding, the same public ip can be used for other public service such as running a web server.
e.g.
static (inside,outside) tcp x.x.x.x 80 z.z.z.z 80 netmask 255.255.255.255
Hi Jackko
I think you understood the question fully, judging by your answer.
I did try that altered static statement, which looks good. However if I apply it then my email seems to stop flowing in!!
I am not sure if I have made a mistake somewhere or not. I post my config in case that might have some bearing. Do I need to upgrade to v7.0 do you think?
Thanks for your input.
HBalf
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname HistPIX
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol pptp 1723
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
no fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list outside-in permit tcp any host x.x.x.51 eq smtp
access-list outside-in permit tcp any host x.x.x.62 eq pptp
access-list outside-in permit gre any host x.x.x.62
pager lines 24
logging on
logging buffered debugging
logging trap warnings
logging host inside 172.16.0.2
mtu outside 1500
mtu inside 1500
ip address outside x.x.x.50 255.255.255.240
ip address inside 172.16.0.1 255.255.0.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 x.x.x.52-x.x.x.60 netmask 255.255.255.240
global (outside) 1 x.x.x.61 netmask 255.255.255.240
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) x.x.x.51 172.16.0.4 netmask 255.255.255.255 0 0
access-group outside-in in interface outside
route outside 0.0.0.0 0.0.0.0 x.x.x.49 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
tftp-server inside 172.16.0.2 pix/config/viatest
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:xxxx
: end
[OK]
Gold
no static (inside,outside) x.x.x.51 172.16.0.4 netmask 255.255.255.255
static (inside,outside) tcp x.x.x.51 25 172.16.0.4 25 netmask 255.255.255.255
clear xlate
just wondering if you did issue "clear xlate" after modifying the static statements.
Hi jaccko
Thanks for your comments. (I normaly save the config and reload to ensure changes have taken.) I made the changes and it still does not work! I have copied the show xlate below, whcih verfies the command 'took' properely - or so I presume.
I have a no fixup smtp 25 command - would this make any difference to the static command I am trying to get to work?
Global x.x.x.56 Local 172.16.0.103
Global x.x.x.51 Local 172.16.0.4
HistPIX(config)# clear xlate
HistPIX(config)# show xlate
3 in use, 4 most used
Global x.x.x.57 Local 172.16.0.103
Global x.x.x.58 Local 172.16.0.4
PAT Global x.x.x.51(25) Local 172.16.0.4(25)
4 in use, 4 most used
Global x.x.x.59 Local 172.16.0.171
HistPIX(config)#
(The .103 and .171 are a syslog server and a MAC user, if you are wondering why the traffix does not come from 172.16.0.4)
Thanks for your help
HB
119
