Anti-DOS options?
Applied the following "open" configuration, and all seemed to be well. Then started experiencing problems logging onto a Windows 2000 domain (on vlan-7) from all vlan-x interfaces. The login problems were sporadic: the same users would have success on one machine, then failure. What does this have to do with FWSM, you ask?
We were running Nessus and ISS scans during the process. Is there default behavior in place on FWSM/PIX that would take an interface down for a brief interval, perhaps if a DOS attack were detected?
FWSM Version 1.1(2)
no gdb enable
nameif vlan11 vlan-11 security10
nameif vlan2 vlan-2 security20
nameif vlan3 vlan-3 security50
nameif vlan4 vlan-4 security80
nameif vlan5 vlan-5 security30
nameif vlan7 vlan-7 security90
nameif vlan8 vlan-8 security40
nameif vlan9 vlan-9 security0
nameif vlan6 inside security100
hostname FWSM
fixup protocol ftp 21
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol http 80
no names
access-list vlan-11 permit icmp any any
access-list vlan-11 permit ip any any
access-list vlan-2 permit icmp any any
access-list vlan-2 permit ip any any
access-list vlan-3 permit icmp any any
access-list vlan-3 permit ip any any
access-list vlan-4 permit icmp any any
access-list vlan-4 permit ip any any
access-list nat-11 permit ip any any
access-list nat-2 permit ip any any
access-list nat-3 permit ip any any
access-list nat-4 permit ip any any
access-list nat-5 permit ip any any
access-list nat-7 permit ip any any
access-list nat-8 permit ip any any
access-list nat-9 permit ip any any
access-list nat-inside permit ip any any
access-list vlan-5 permit icmp any any
access-list vlan-5 permit ip any any
access-list vlan-7 permit icmp any any
access-list vlan-7 permit ip any any
access-list vlan-8 permit icmp any any
access-list vlan-8 permit ip any any
access-list vlan-9 permit icmp any any
access-list vlan-9 permit ip any any
access-list vlan-inside permit icmp any any
access-list vlan-inside permit ip any any
no pager
logging on
logging timestamp
logging console emergencies
logging monitor alerts
logging trap informational
logging history informational
logging host inside 192.168.6.3
icmp permit any vlan-11
icmp permit any vlan-2
icmp permit any vlan-3
icmp permit any vlan-4
icmp permit any vlan-5
icmp permit any vlan-7
icmp permit any vlan-8
icmp permit any vlan-9
icmp permit any inside
mtu vlan-11 1500
mtu vlan-2 1500
mtu vlan-3 1500
mtu vlan-4 1500
mtu vlan-5 1500
mtu vlan-7 1500
mtu vlan-8 1500
mtu vlan-9 1500
mtu inside 1500
ip address vlan-11 192.168.1.254 255.255.255.0
ip address vlan-2 192.168.2.254 255.255.255.0
ip address vlan-3 192.168.3.254 255.255.255.0
ip address vlan-4 192.168.4.254 255.255.255.0
ip address vlan-5 192.168.5.254 255.255.255.0
ip address vlan-7 192.168.7.254 255.255.255.0
ip address vlan-8 192.168.8.254 255.255.255.0
ip address vlan-9 30.0.0.254 255.255.255.0
ip address inside 192.168.6.254 255.255.255.0
no failover
arp timeout 14400
nat (vlan-11) 0 access-list nat-11
nat (vlan-2) 0 access-list nat-2
nat (vlan-3) 0 access-list nat-3
nat (vlan-4) 0 access-list nat-4
nat (vlan-5) 0 access-list nat-5
nat (vlan-7) 0 access-list nat-7
nat (vlan-8) 0 access-list nat-8
nat (vlan-9) 0 access-list nat-9
nat (inside) 0 access-list nat-inside
access-group vlan-11 in interface vlan-11
access-group vlan-2 in interface vlan-2
access-group vlan-3 in interface vlan-3
access-group vlan-4 in interface vlan-4
access-group vlan-5 in interface vlan-5
access-group vlan-7 in interface vlan-7
access-group vlan-8 in interface vlan-8
access-group vlan-9 in interface vlan-9
access-group vlan-inside in interface inside
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet timeout 5
ssh timeout 5
terminal width 80
: end
1 REPLY
Re: Anti-DOS options?
To the best of my knowledge, there is no such thing where FWSM/PIX will bring down an interface upon a DoS attack or similar.
You can check this with 'show interface' to see if the "interface resets" counter has incremented. If so, the DoS might might have caused the interface to seize, max-out...etc.
Hope that helps.
Yusuf
134
