AnyConnect Linux Client problems
I'm using version 2.2.0133 and every time I attempt to connect I get the following error message...
Connection attempt has failed due to server certificate problem.
I've tried running as a regular user, using sudo, and running as root, all with the same result.
Any ideas why this is happening? TIA!
Re: AnyConnect Linux Client problems
I am using Ubuntu 8.04 and had to do the following:
sudo ln -s /usr/lib/libnss3.so.1d /usr/lib/libnss3.so
sudo ln -s /usr/lib/libplc4.so.0d /usr/lib/libplc4.so
sudo ln -s /usr/lib/libnspr4.so.0d /usr/lib/libnspr4.so
sudo ln -s /usr/lib/libsmime3.so.1d /usr/lib/libsmime3.so
See here for more info:
http://ubuntuforums.org/showthread.php?t=839362&highlight=anyconnect
Found this and tried it and it did absolutely nothing.
540
