apc ups management thru dmz
hi all,
i have a 5510 asa box and i have front end exchange server in dmz which is 172.16.1.0/24 network and my inside network is 192.168.1.0/24 which is having backend exchange and the setup is working fine.
i ihave enabled icmp traffic from dmz to inside so i can ping to inside and i have one apc ups which is in inside network im not able to ping or i cannot perfom any activity to its management port.
is something need to be enabled.by default all the communication from inside to dmz and vice versa is enabled.so what could be the problem.
kindly suggest
Regds
Binoy
Re: apc ups management thru dmz
Why do you need to communicate from a DMZ server to a UPS on the inside? That hole should not be opened up.
hi clark
tnx for your reply.what i need is incase of power failure my front end exchange server which is in dmz need to get requests from the apc ups port to shutdown automatically thats what i need.
That makes perfect sense! Since the UPS is on the inside and will send SNMP to the DMZ server, we need to look at the ACL applied to the inside interface. Is there one applied? Can you post the relevent part?
123
