Community Member
Application Timeout !!!
Hi All ,
Just a small query , I have a PIX to PIX (site to site) VPN and I am able to successlly ping the server at site B from any computer from site A , but the main Application is loaded in the server at Site B.
The client Applications are loaded on all workstations on Site A.These applications tend to time out after 5 minuites of inactivity , these are Oracle based Applications called IFS which runs from the client machines.
I have done a continious ping ( with the ping x.x.x.x -t ) option in the Dos prompt of the client machine , and then run the client application , the Ping gets a continious reply but the application times out after 5 min.
Is it to do with any ISAKMP lifetime on the firewall or what I am not understanding , The Application works fine without any timeout on all the local machines at the Site B where the server is actually located.But from the machines on site A it times out ........
Any idea why It could be , or is it a VPN issue or an Application issue......
Please give your advice.....
Community Member
Re: Application Timeout !!!
Hi ,
One more thing forgot to tell you to try.
Try to ping with packet site 1300, 1400 ,1500 see it is timeout or not.
ping -l 1500
It might be a MTU issue. But I do not think the application will use very large packet to keepalive. Sniffer trace will be the best choice at this moment.
Best Regards,
Community Member
Modify your Oracle clients configuration
file to edit: sqlnet.ora
add this line: SQLNET.EXPIRE_TIME=10
you'll find more info here:
