Community Member
Are mulitple modes allowed for SSLVPN on a single ASA 5540?
Can you configure both clientless and sslvpn client (svc) on the same device? Can a user access both? That is, for example if you configure clientless for OWA and svc for another application, will a user be able to access/use both?
Thanks!!
1 ACCEPTED SOLUTION
Community Member
Re: Are mulitple modes allowed for SSLVPN on a single ASA 5540?
Yes you can, the way we did it was to create a group policy for each with an alias for each and to enable the drop down box for group policy selection for the user. So when a user accesses the WebVPN site under the username and password boxes there is a box to select which way they want to connect.
Community Member
Community Member
Excellent! I have setup a lab environment for this on Friday so I'll try out your solution on Monday and let you know how it goes. Thank you so much!!!
Community Member
Yes, it worked like a charm. Thanks! I had to upgrade to version 7.1 or newer have sslvpn client capability but other than that it was pretty straightforwad and painless. Cheers!
104
