arp FWSM problem
I have FWSM Firewall Version 2.3(3) with multiple contex mode. How can I clear arp table in one of contextes (i.e. admin context). clear arp doesn't work.
Thanks in advance.
1 ACCEPTED SOLUTION
Re: arp FWSM problem
hey buddy,
you do n't look like in the configuration mode
try this,
FWSM01/Administrator#config t
FWSM01/Administrator(config)#clear arp
Let me know if that works or not.
Enjoy!!
hi .. you need to move to the desired context and from config mode enter the clear arp command.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_command_reference_chapter09186a0080350595.html#wp1503277
fwsm/context_name(config)# clear arp
I hope it helps .. please rate it if it does !!
I tried that but that command doesn't exist (although it is in command refernece). Also if you type clear ? you don't get arp as an option in a list. It apperas only if you type sh arp ? then it prints out that you can use clear arp, but I repeat it doesn't exist.
here is printout:
FWSM01/Administrator# clear arp
Type help or '?' for a list of available commands.
thanks
hey buddy,
try this,
Enjoy!!
Hello
It works. Thank you very much
250
