ASA 5500 VPN with failover IPSec tunnel
can we configure ASA appliance with two IPsec tunnel with same encryption doamin. Something like track a tunnel (like how we used to track an interface in HSRP) and if it fails then switch over to the second IPSec tunnel with encryption domain.
also is this correct - ASA doesnt support BGP either on version 7 or 8 ?
1 REPLY
Silver
Re: ASA 5500 VPN with failover IPSec tunnel
I have seen instances where failover is possible with Active/ Standby but not on the same ASA. As far as I know , BGP is not supported on ASA . You will need a router in front of ASA.
355
