07-20-2006 02:34 AM - edited 02-21-2020 01:03 AM
Hi, how many logical interfaces does the ASA 5505 support ?
The old PIX 506E supports 4 total logical interfaces (hw and vlan) and I expect the ASA 5505 does the same or better
thank you in advance
renato
07-20-2006 03:44 AM
The data sheet says "The Cisco ASA 5505 features a flexible 8-port 10/100 Fast Ethernet switch, whose ports can be dynamically grouped to create up to three separate VLANs for home, business, and Internet traffic for improved network segmentation and security."
07-20-2006 07:06 AM
So from 4 logical lan on PIX 506E we have only 3 logical lan in ASA 5505 ?
The solution for 506E owners is the ASA 5510 ?
07-25-2006 07:14 AM
No, 506E replacement is ASA5505 in both featurerize and pricing.
08-03-2006 05:28 AM
Hi, how to replace the 506E with less capabilities from ASA5505 ?
Should I reduce the logical zones in 506E sites ?
thanks
09-29-2006 06:10 AM
Hi, is there any update with the newer releases on the logical interfaces supported by ASA 5505 ?
renato
