Community Member
ASA 5505 DHCP Range
Does anyone know, does the ASA 5505 only allow a range of 30 addreses or can you use the whole subnet if needed?
1 REPLY
Community Member
Re: ASA 5505 DHCP Range
Depends on where the address are, if you are referring to the external interface I.e route able address then you can only use address allocated by the ISP.
Regards MJ
144
