ASA 5510 Accessing Inside Interface While using VPN
shawnreis
We need to be able to access the Device via SSH while connected VIA VPN.
I have added it to the management access:
pix(config)#management-access inside
And it says I need to add the correct access. I have SSH added to my ACL on the outside interface coming in and can SSH into servers on the inside.
So do I also need to add ac ACL to the inside Interface to allow this ssh access to the Device?
Moe
7 Replies 7
acomiskey
Level 10
Level 10
No, all you should need is...
ssh inside
I tried that with no luck. Just to make sure, I removed the management access and readded:
ASA(config)# management-access inside-vpn
Please remove the management access before configure a new one
ASA(config)# no management-access inside-vpn
I also have the SSH setup:
ASA# show ssh
Timeout: 5 minutes
Versions allowed: 1 and 2
192.168.192.0 255.255.255.0 inside-vpn
xx.xx.32.0 255.255.255.128 inside-vpn
I know the SSH works since I have used it.(while not being connected via VPN) I have also set my IP address to match one in our VPN DHCP range and from there I can SSH into the Device. Just not directly while VPN'd in.
Although while connected to the VPN I can ssh into a server and then into the device. I would rather not have to do that.
Moe
If you are split tunneling, make sure the inside interface is part of you split tunnel acl.
When I setup my split tunneling I made a standard ACL and that just says Permit my network. (and is working fine)
Do I need a line just for my Inside interface?
It depends, is inside interface part of "my network"?
Yes it is.
I can SSH into it from anywhere on my network just not while connected to the VPN. I can Telnet to it and ping it while using VPN, just not SSH.
And as always:
Thanks for your help and patience.
