ASA 5510 and VPN access to remote site over Ext WAN
ASA 5510
int client IP 172.0.1.XXX /24
VPN Client IP 172.0.1.248 /29
Static routes in the ASA
1) 0.0.0.0 --- points to router1
2) 172.29.1.1 --- Points to router2
3) 172.29.1.2 --- Points to router2
Router1 Internet connection // VPN access in path
Router2 Dedicated line to offsite hosting // Dedicated routes in ASA
................../---- ROUTER 1
..Inside -- ASA --- outside (switch 2 rtrs)
..................\---- ROUTER 2
If a PC from inside the network wants to talk with 172.29.1.2 it will work fine. If I VPN into the router, I can connect to anything onsite. I cannot talk to 172.29.1.1 or .2
At first I thought it was the same-security-traffic issue and applied same-security-traffic permit inter-interface then i tried same-security-traffic permit intra-interface.
Both commands failed, Looking at the diagram I think its something with the fact I VPN into this ASA. Now router2 see's our ASA as its external. So it see's our 208.12.*.* as the outgouing address and dest is 172.29.1.1 or .2
I did a capture on the outside interface and I see the following. Now these caps are from the inside PC's accessing the website.
3000 packets captured
1: 15:03:38.176733 208.12.*.*.60404 > 172.29.1.2.443: P 2697372408:2697372444(36) ack 2813073572 win 64360
2: 15:03:38.179815 208.12.*.*.63637 > 172.29.1.2.443: P 3373326671:3373326705(34) ack 3255654279 win 64512
3: 15:03:38.179876 208.12.*.*.60404 > 172.29.1.2.443: P 2697372444:2697372480(36) ack 2813073572 win 64360
4: 15:03:38.180181 172.29.1.2.443 > 208.12.*.*.27133: . ack 838693750 win 65456
5: 15:03:38.180212 172.29.1.2.443 > 208.12.*.*.26920: P 1652457319:1652457373(54) ack 2226176804 win 65482
Can someone point me in the right direction on how I would get the VPN working so it too can connect to those websites?
Re: ASA 5510 and VPN access to remote site over Ext WAN
Did you try to do NONAT for the traffic from 172.0.1.0 going to 172.29.1.0
Something like this:-
access-list NONAT permit ip 172.0.1.0 255.255.255.0 172.29.1.0 255.255.255.0
nat (Inside) 0 access-list NONAT
I didnt think I needed too because it works from the local lan to 172.29. Its only an issue when you VPN into the ASA
Are you encrypting everything or split-tunneling on the VPN client?
Either way you need to make sure the VPN client knows about the remote site IP subnet - and allow intra-interface communications.
HTH>
its encrypting everything
I did same-security ... intra already and it didnt work.
I shoul then add the no nat statement
Will that mess anything up with the internal connection?
No - it will be an addition to an existing access-list.
HTH>
thanks
I will try it after 5 PM EDT when they close. thanks in advance if this resolves it
ill post back
184
