ASA 5510 dual ISP
Does the ASA 5510 support dual ISP support/redundancy/failover/load-balancing? It looks like the 5505 does, but does the 5510?
5505 Info:
Cisco ASA 5505 Security Plus bundle
Includes Cisco ASA 5505, unlimited users, 8-port Fast Ethernet switch, stateful firewall, 25 IPsec VPN peers, 2 SSL VPN peers, stateless Active/Standby high availability, dual ISP support, DMZ support, 3DES/AES license, and 1 expansion slot
150 Mbps/100 Mbps
ASA5505-SEC-BUN-K9
1 REPLY
Re: ASA 5510 dual ISP
While it is specifically mentioned that ASA5505 support dual-ISP link, other ASA/PIX models also support this feature.
Refer to the following link:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00806e880b.shtml
AK
447
