ASA 5510 - easy way disable Lan to Lan ?
Here's my question. I used to have all of my IPSEC L2L tunnels on the VPN Concentrator. I had the ability there to enable or disable each individual IPSEC L2L tunnel. On my ASA there does not appear to be such a function...at least not on the ASDM as far as I can see.
One thing I can do is remove the password for the tunnel but it seems lot more burdensome.
What would be the best/easiest way of enabling/disabling L2L tunnels ??
TIA
Re: ASA 5510 - easy way disable Lan to Lan ?
An all or none way would be to disable isakmp on the outside interface. If you need to disable an individual tunnel, you could remove the pwd like your doing or what we do is remove the ACL from the cryptomap.
HTH and please rate.
thanks for the response. as I had thought...nothing really as easy as what previously existed in the concentrator.
255
