ASA 5510 failover + SSL VPN licences
lenpet_hun
hi everyone,
having two ASA 5510 configured in active/standby failover, do i have to buy ssl vpn licences to both devices to extend capabilities? what if i change it to active/active? license in question is ASA5500-SSL-25=. thanks!
peter
6 Replies 6
lenpet_hun
can anyone pls give me an answer?
tomranson
Hi all,
I too am looking for an answer to this; running 2x 5520's in A/S and looking to purchase 750 SSL VPN licenses for the failover cluster.
Do we indeed need to purchase licenses for BOTH pieces of hardware, given that they are in a f/o pair?
Many thanks,
Tom
cdusio
Level 4
Level 4
Yes you need the licenses for both. As far as active active goes that requires multiple context mode to work. I know that multiple context mode doesn't support VPN failover so just keep that in mind.
Also active active failover is not supported on the 5510 only active standby.
Chris
Actually I was mistaken.
I have one doc that shows active/standby only for the 5510 and another that shows it is available so I apoligize about that. You do need the sec plus license for that.
2 referencing docs
http://cisco.com/en/US/partner/docs/security/asa/asa71/asdm51/webhelp/gen_info_licenses.html
http://cisco.com/en/US/partner/products/ps6120/prod_models_comparison.html
hi Chris,
thanks for your answer! so a/a failover is not an option anymore... but even in a/s, having to buy twice the amount of licences we need is a bit of a rip off. are you absolutely sure we need to have the extra license for both devices?
Yes, you have to buy the license for both devices.
Edgar
