Community Member
ASA 5510 - SSL VPN CLIENTLESS - Remote Desktop
Is it possible to make a remote desktop connection with a browser via clientless SSL VPN ? I know I can do it with anyconnect SSL client but can I do it without a client ?
1 ACCEPTED SOLUTION
Community Member
Re: ASA 5510 - SSL VPN CLIENTLESS - Remote Desktop
Yes it is possible, first you will need to make sure you have the RDP plugin uploaded to the ASA. When you edit you bookmarks you will see an option for RDP.
Community Member
i think is not ,clientless ssl vpn only support http and https and cifs.
Community Member
Yes through SSL VPN you launch a java based client that you must load on the ASA then you get RDP through the SSL browser connection.
Community Member
Community Member
so where can I find the RDP plugin ? and where should I upload ?
thanks
Community Member
thx. that plugin solved my problem..
1020
