ASA 5510 - struggling with static routes
Situation (best viewed with 'courier new'):
(OfficeLAN) (ProdLAN)
Internet|--|Router|---------|ASA|--------
(DMZ)
I want to use the ASA BOX as the default Gateway for the LAN. on the ASA is a default route configured wich forwards the 'internet-traffic' to the Internet.
but somehow the asa simply ignores its duties to forward the traffic to the internet. Traffic destined to the production LAN and the DMZ is working fine.
Any hints for a depressive technician?
Re: ASA 5510 - struggling with static routes
Turn on logging so you can see any error messages when you try to ping something on the Internet from the Inside or DMZ.
pix#(config) logging on
pix#(config) logging console debug
If your return packet is being denied on the outside interface, modify your outside ACL.
access-list inbound permit icmp any any echo-reply
access-group inbound in interface outside
If you see that DNS replies are being blocked by the outside interface, add this command:
dns domain-lookup outside
If you have a DNS server on the DMZ, add it as well.
dns domain-lookup DMZ
Hope this helps,
Dave
Gold
just wondering what exactly you are referring to when you mentioned "the asa simply ingores its duties to forward the traffic to the internet".
do "debug icmp trace" in order to verify whether the asa is performing as expected.
also please verify that the nat/pat has been configured for internet browsing.
e.g.
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
224
