ASA 5510 SVC Issues
I have implemented an ASA 5510 with a single subnet behind the firewall, 192.168.0.0/24
I have followed all the instructions in cisco documentation and I can connect no problems to the VPN. I am assigned an IP address from the dhcp server 192.168.0.100
However the only thing I can see (using ping is the default gateway - which happens to be the ASA internal interface192.168.0.1.
I am tunneling all traffic through the tunnel and local lan is disabled.
My only route on the firewall is 0.0.0.0 0.0.0.0 that points to our external router.
I have NO access rules or filters to prevent the traffic.
As I mentioned the only device I can see on the same subnet is the inside interface, any ideas as the routing on the internal subnet should already be known.
1 REPLY
Re: ASA 5510 SVC Issues
Without your configuration, I can't guess too much, but check your NAT acl to make sure that there is a nonat (nat 0) statement for your internal networks to your VPN pool.
--Jason
106
