Community Member
ASA 5510 VPN does not work after trying to add DMZ
i had asa 5510 set up for remote access VPN and everything was working fine untill i tried to add DMZ. VPN users cannot connect any more and to make things worst i cannot backtrack and fix the problem. here are bits of my config:
interface Ethernet0/0
description OUTSIDE
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/1
description INSIDE
nameif inside
security-level 100
ip address
interface Ethernet0/2
description DMZ
nameif dmz
security-level 10
ip address
access-list nonat extended permit ip
access-list split standard permit
(there are not other access lists - on any interface in any direction)
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1
static (inside,dmz) netmask
static (dmz,outside) interface netmask
the only part that i really added was the last two lines. that's when i figured out that users cannot VPN so i didn't continue with DMZ setup. and after adding the last line the response that i got was:
WARNING: static redireting all traffics at outside interface;
WARNING: all services terminating at outside interface are disabled.
now even if i try to
no static (inside,dmz) netmask
no static (dmz,outside) interface netmask
the VPN does not work.
any help is appreciated...
Re: ASA 5510 VPN does not work after trying to add DMZ
When you used the dmz static you broke everything else. That command stated that for the interface outside that ip only translates to the dmz server.
remove the static (dmz,outside) interface netmask
re-apply your crypto's to the outside interface. verify that works.
use static pat for your dmz:
static (inside,outside) tcp interface port_number port_number netmask
Staic PAT:
Hope this helps
Please rate if helpful!
Community Member
hi chad, this was extremly helpful. thanks a lot. one more question:
static (inside,outside) tcp interface [port number] [port number] netmask
this command forwards all traffic from [port number] coming in on outside interface to [port number] on, right? when i used
i was able to access the internet from DMZ. without it i cannot. any ideas? thanks again.
This will pat your dmz clients using the global interface.
nat (dmz) 1 (all dmz hosts)
nat (dmz) 1 (only that server)
The static would be needed if you had a service running on that server like a web page. Then you would create the static command using port 80.
