ASA 5510 VPN Problem
Hello All,
We have a ASA 5510 that is configured as a Remote Access VPN Server using Preshared keys. When a Remote VPN Client tries to connect, the phase-1 connectivity gets established but phase 2 fails. The following errors are displayed on the ASA 5510:
Received encrypted packet with no matching SA, dropping
Session disconnected. Session Type IPSec, Reason: crypto map policy not found
Removing peer from correlator table failed, no match!
QM FSM error (P2 struct &0x2f23fc8, mess id 0xf8d08701)!
Rejecting IPSec tunnel: no matching crypto map entry for remote proxy on interface outside
PHASE 1 COMPLETED
Please help
Best Regards,
Manoj Rathod
Re: ASA 5510 VPN Problem
Hi Manoj,
Can you post the VPN configuration? The error was related to the crypto map - either does not exists or not bind to outside interface.
Your config will provide a good clue.
Rgds,
AK
Hi AK,
Thanks for your reply. Please find attached the running config of ASA. Do let me know what is wrong?
Best Regards
Manoj Rathod
Hi Manoj,
Sorry for the late reply.
Since your VPN is meant for VPN client that should allow connection from any anywhere, try to remove the "crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20".
Rgds,
AK
Hi AK,
Thanks for your advice, I shall try the same and let you know.
Best Regards
Manoj Rathod
615
