Community Member
ASA 5510: Want to route into the same interface to reach another network
I have configured an ASA 5510 with many services, most of them are working ok (DMZ, Internet, Routing to branch offices) but i cannot route computers on newtworks 192.168.0.0/16 to network 193.168.1.0/24. To reach 193.168.1.0/24 need pass through 192.168.0.249 (Located in the same network of ASA). Here's the configuration
ASA Version 8.2(1)
hostname ASAFCHFW
domain-name midominio.com
enable password 6Jfo5anznhoG00fM encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
 nameif Outside
 security-level 0
 ip address xxx.yyy.zzz.123 255.255.255.248
interface Ethernet0/1
 nameif Branch_Office
 security-level 100
 ip address 192.168.2.1 255.255.255.0
interface Ethernet0/2
 nameif DMZ
 security-level 10
 ip address 172.16.31.1 255.255.255.0
interface Ethernet0/3
 nameif Inside
 security-level 100
 ip address 192.168.0.2 255.255.255.0
interface Management0/0
 nameif management
 security-level 100
 management-only
boot system disk0:/asa821-k8.bin
ftp mode passive
dns server-group DefaultDNS
 domain-name farmaciachavez.com.bo
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group network POSLINKSER
 network-object host 192.168.41.101
 network-object host 192.168.41.102
 network-object host 192.168.41.103
 network-object host 192.168.41.104
 network-object host 192.168.41.105
 network-object host 192.168.41.106
 network-object host 192.168.27.101
 network-object host 192.168.27.102
 network-object host 192.168.27.103
 network-object host 192.168.27.104
 network-object host 192.168.27.105
 network-object host 192.168.27.106
 network-object host 192.168.42.101
 network-object host 192.168.42.102
 network-object host 192.168.42.103
 network-object host 192.168.42.104
 network-object host 192.168.42.105
 network-object host 192.168.42.106
 network-object host 192.168.23.101
 network-object host 192.168.23.102
 network-object host 192.168.23.103
 network-object host 192.168.23.104
 network-object host 192.168.23.105
 network-object host 192.168.23.106
 network-object host 192.168.39.101
 network-object host 192.168.39.102
 network-object host 192.168.39.103
 network-object host 192.168.39.104
 network-object host 192.168.39.105
 network-object host 192.168.39.106
 network-object host 192.168.40.101
 network-object host 192.168.40.102
 network-object host 192.168.40.103
 network-object host 192.168.40.104
 network-object host 192.168.40.105
 network-object host 192.168.40.106
 network-object host 192.168.0.62
access-list dmz_in extended permit ip host 172.16.31.2 any
access-list dmz_in extended permit tcp host 172.16.31.2 any
access-list dmz_in extended permit udp host 172.16.31.2 any
access-list dmz_in extended permit tcp host 172.16.31.2 any eq 3000
access-list dmz_in extended permit tcp host 172.16.31.2 any eq https
access-list dmz_in extended permit udp host 172.16.31.2 any eq domain
access-list dmz_in extended permit tcp host 172.16.31.2 any eq pop3
access-list dmz_in extended permit tcp host 172.16.31.2 any eq smtp
access-list dmz_in extended permit tcp host 172.16.31.2 any eq www
access-list dmz_in extended permit tcp host 172.16.31.2 any eq 1000
access-list dmz_in extended permit tcp host 172.16.31.2 any eq echo
access-list Inside extended permit ip any any
access-list Inside extended permit icmp any any
access-list Inside extended permit tcp any any
access-list 100 extended permit ip any host xxx.yyy.zzz.122
access-list 100 extended permit tcp any host xxx.yyy.zzz.122
access-list 100 extended permit udp any host xxx.yyy.zzz.122
access-list linkser extended permit ip any 193.168.1.0 255.255.255.0
access-list linkser extended permit ip 193.168.1.0 255.255.255.0 any
access-list linkser extended permit tcp 193.168.1.0 255.255.255.0 any
access-list linkser extended permit tcp any 193.168.1.0 255.255.255.0
access-list linkser extended permit ip 192.168.0.0 255.255.255.0 193.168.1.0 25
.255.255.0
access-list netflow-export extended permit ip any any
pager lines 24
logging enable
logging buffered debugging
logging asdm informational
no logging message 106015
no logging message 313001
no logging message 313008
no logging message 106023
no logging message 710003
no logging message 106100
no logging message 302015
no logging message 302014
no logging message 302013
no logging message 302018
no logging message 302017
no logging message 302016
no logging message 302021
no logging message 302020
flow-export destination Inside 192.168.0.54 9996
flow-export template timeout-rate 1
flow-export delay flow-create 60
mtu Outside 1500
mtu Branch_Office 1500
mtu DMZ 1500
mtu Inside 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
icmp permit host 192.168.0.43 Outside
icmp permit any Outside
icmp permit any DMZ
asdm image disk0:/asdm-647.bin
asdm history enable
arp timeout 14400
global (Outside) 101 interface
global (DMZ) 101 interface
global (Inside) 102 interface
global (Inside) 102 192.168.0.0 netmask 255.255.255.0
nat (Branch_Office) 101 0.0.0.0 0.0.0.0
nat (DMZ) 101 0.0.0.0 0.0.0.0
nat (Inside) 102 access-list linkser
nat (Inside) 101 0.0.0.0 0.0.0.0
static (DMZ,Inside) 172.16.31.0 172.16.31.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.2.0 192.168.2.0 netmask 255.255.255.0
static (Inside,DMZ) 192.168.0.0 192.168.0.0 netmask 255.255.255.0
static (Inside,Branch_Office) 192.168.0.0 192.168.0.0 netmask 255.255.255.0
static (DMZ,Branch_Office) 172.16.31.0 172.16.31.0 netmask 255.255.255.0
static (Branch_Office,DMZ) 192.168.2.0 192.168.2.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.3.0 192.168.3.0 netmask 255.255.255.0
static (Branch_Office,Inside) 172.16.1.0 172.16.1.0 netmask 255.255.255.0
static (Branch_Office,Inside) 172.16.2.0 172.16.2.0 netmask 255.255.255.0
static (Branch_Office,Inside) 172.16.3.0 172.16.3.0 netmask 255.255.255.0
static (Branch_Office,DMZ) 172.16.1.0 172.16.1.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.44.0 192.168.44.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.21.0 192.168.21.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.20.0 192.168.20.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.35.0 192.168.35.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.37.0 192.168.37.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.43.0 192.168.43.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.45.0 192.168.45.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.28.0 192.168.28.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.33.0 192.168.33.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.30.0 192.168.30.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.25.0 192.168.25.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.27.0 192.168.27.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.26.0 192.168.26.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.34.0 192.168.34.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.23.0 192.168.23.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.39.0 192.168.39.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.29.0 192.168.29.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.22.0 192.168.22.0 netmask 255.255.255.0
static (Branch_Office,Inside) 192.168.32.0 192.168.32.0 netmask 255.255.255.0
static (DMZ,Outside) xxx.yyy.zzz.122 172.16.31.2 netmask 255.255.255.255 dns
static (Inside,Inside) 193.168.1.0 192.168.0.249 netmask 255.255.255.255
access-group 100 in interface Outside
route Outside 0.0.0.0 0.0.0.0 xxx.yyy.zzz.121 20
route Branch_Office 172.16.1.0 255.255.255.0 192.168.2.2 1
route Branch_Office 172.16.2.0 255.255.255.0 192.168.2.2 1
route Branch_Office 172.16.3.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.1.0.0 255.255.192.0 192.168.2.2 1
route Branch_Office 192.168.20.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.21.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.22.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.23.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.25.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.26.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.27.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.28.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.29.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.30.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.32.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.33.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.34.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.35.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.37.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.39.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.43.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.44.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.45.0 255.255.255.0 192.168.2.2 1
route Branch_Office 192.168.100.0 255.255.255.0 192.168.2.2 1
route Inside 193.168.1.0 255.255.255.0 192.168.0.249 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication http console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
http 192.168.0.0 255.255.255.0 Inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet 0.0.0.0 0.0.0.0 Branch_Office
telnet 172.16.31.0 255.255.255.0 DMZ
telnet 192.168.0.0 255.255.255.0 Inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
username eguerra password dr6zkC4iOPQHLH5f encrypted privilege 15
class-map netflow-export-class
 match access-list netflow-export
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect icmp
  inspect icmp error
policy-map netflow-export-policy
 class netflow-export-class
  flow-export event-type all destination 192.168.0.54
service-policy global_policy global
prompt hostname context
Cryptochecksum:405977f6d76e3cdbb66b576c8c8cbc64
: end
135
