03-24-2006 12:39 AM - edited 02-21-2020 12:47 AM
Dear All,
I am in the process to implement the above title product to one of customer.
I am very familar with Firewall configuration but the AIP-SSM module is the one I am doing first time.
Please I need yours help to do the configuration.
Is there any way using ASDM to configure it, If so please give me the steps and procedures to complete the job
Thanks in advance
swamy
Solved! Go to Solution.
03-24-2006 01:22 AM
Hi S,
Very easy:
You log into the ASA, enter enable mode and then connect to the IPS via command "session 1".
You are then connected to the console of the IPS. Enter the username "cisco" and password "cisco" and run setup for the basic config (IP addres etc). After this you can either connect directly to the IPS via web browser or via ASDM.
I would recommend then reading the config guide for the IPS as it can be very intensive (configuring/tweaking signatures etc)
Hope this helps!
Cheers
JC
03-24-2006 01:22 AM
Hi S,
Very easy:
Hope this helps!
Cheers
JC
