ASA 5540 7.2(2) crash and reboot
Today i have a problem with a Cisco ASA 5540, suddenly it crash and rebooted. All that i see is the 99% utilization of the CPU in the crashinfo file.
The device was working normally, with no configuration or hardware changes
I attach the crash-info file
Re: ASA 5540 7.2(2) crash and reboot
After analyzing the crashinfo, it looks like that you ate hitting this bug
CSCsk33743 High CPU followed by reload with Thread Name: IP Address Assign
You may check this here:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsk33743
This is one-time crash so issue is Unreproducible.
JK
Plz rate helpful posts-
~BR Jatin Katyal **Do rate helpful posts**
Thanks for your help
Can you tell me if exist an IOS version more stable that the version 7.2(2)?
This to consider the possibility of the update in case of a new crash.
You may go for
8.0.4 (45)
Much stable than 8.2.1
JK
518
