ASA Active/Active Configuration
Dear All,
In configuring Active/Active mode of ASA, most examples are stating using
2 customers for Active/Active. If I only get 1 customer with 4 interfaces as
following:
1) Outside
2) Inside
3) DMZ
4) VPN
Can I still use the Active/Active mode?
If so, then how to allocate the interfaces to the 2 failover groups? Let
assume:
Failover group 1: Outside and DMZ
Failover group 2: VPN and Inside
That means ASA_A is primary of Group1, while ASA_B is primary of Group2. If
so, is the traffic between Outside and Inside has problem? Since they are
crossing the 2 failover group on the 2 ASA.
Please correct me and my assumption. A sample configuration would be much appreciate.
Thanks in advance.
Br,
Sam
339
