Community Member
ASA and wan links
We currently have 2 offices located in different states. We have a point 2 point conencting them and each location has its own cable modem internet connection.
I want to make it where if one cable modem connection goes down to have it auto roll to the other side.
the routers connecting them are two 1841. I beleive if i add a weighted default router on each to point to the ASA on the other side. Then enable routing between the ASA will accomplish this. But to get it to work, I think we still need to turn off the ASA.
is there something in the ASA that I can turn on which will ping out to the internet and when it sees it cannot connect to route the traffic back inside?
1 REPLY
Community Member
Re: ASA and wan links
I'm not 100% about configuring this on an ASA, however I have set up IPSLA on various routers, that ping out and determine which (weighted) route to use.
Please see the links below...
http://www.cisco.com/en/US/docs/ios/12_4/ip_sla/configuration/guide/hsicmp.html
Steve
128
