ASA appliance Transparent mode - Active Active failover
have the following infrastructure:-
User VLAN (15 - 20) Cisco Access switches --->Cisco 65xx (Layer 3 switch) -----Vlan50---Servers.
Vlan 15 - 20 -----192.168.x.1 / 24 onwards ( where x corresponds to the VLAN number)
Vlan 50 - 192.168.50.y / 24 (where y corresponds to end host IP address)
I want to place the ASA 5520 between Cisco 65xx & the servers, in Active - Active mode.
One of the requirement of Active/Active mode is the need to configure Multiple contexts in the firewall. For multiple context, each context typically uses a different subnet. You can use overlapping subnets, but your network topology requires router & Nat configuration to make it possible from a routing standpoint.
Is it possible configure transparent mode (active ? active failover) without multiple contexts within 192.168.50.y network? If yes, how & If not, what are the possible alternatives to implement the ASA between the Core 65xx switch (VLAN 50) & the servers (192.168.50.y), in active / active failover mode?
Silver
Re: ASA appliance Transparent mode - Active Active failover
Yes, it's possible . for this set up you need to have special license
Thanks for the feedback.
Any idea on the type of license required?
As per Cisco Engineers feedback, one needs to configure multiple context with different subnets & there is no other alternative.
Bronze
What about a FWSM in the 6.5K Chassis. AFAIK the FWSM is also able to do single or multi context in transparent mode. So you have everything you need on the 6.5K Chassis.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_module_configuration_guide_chapter09186a0080577c38.html#wp1201980
The customer has placed an order for the ASA appliance, which can do FW + IPS. As per my knowledge, the FWSM can be configured as a firewall only.
374
