ASA ASDM issue
terry.davis
All,
I have a Cisco ASA 5510 with an IPS module in it. When trying to
connect to this unit with ASDM on port 8443 I get an error
"Certification Validation Error" and on the popup it is asking for
the password. I put in the enable password and then it comes back
and asks for the username and password again and you end up in a
loop until it comes back and says that it cannot connect to the
appliance. I am able to connect to appliance with SSH utilizing the
same username and password. My unit is running ASA software 8.2.1
and the 6.2.1 ASDM software.
Any ideas on what I need to correct this error?
andrew.prince
Level 10
Level 10
check your config
you may need:-
aaa authentication http console LOCAL - which means to auth the HTTPS session with the local username/password.
HTH>
