ASA - Defining VLANS per VPN group basis
Hi all,
Does anyone have a good idea on how to put varius ipsec-remote groups into different VLANS on a ASA box ?
So for instance that vpn-group "sales" gets into VLAN10 - wich is trunked to a switch and can get an IP DHCP address from VLAN10 somewhere ?
Does it require the ASA to be DHCP server ?
Or can it work with a DHCP on the diff. VLANS ?
Kind regards
KD
1 REPLY
Re: ASA - Defining VLANS per VPN group basis
You can configure different pools locally for different groups and bind those accordingly. You can also configure split tunnel for each group that restricts the traffic as per the VLAN subnet.
HTH,
Please rate if it helps,
Kamal
113
