I have a problem with an asa 5540. The internal flash (disk0) is not working anymore.
I would like to use the external disk1 flash to store the startup configuration otherwise every time I reboot I have an empty configuration.
Is this possible? how can I do that? I added the command
boot config disk1:/running-config
but it's completely ignored during startup, also if I issue the command
copy running-config disk1:/running-config
I have the following error
1545 bytes copied in 3.800 secs (515 bytes/sec)open(ffsdev/2/write/41) failed
open(ffsdev/2/write/40) failed
is this error related in some way to the problem?
Another thing: as far as I understood the license is stored in the disk0:, if this is not readable then I load no licence at all, in fact I have this message
This activation key is not valid, use default settings only
this means that once I retrieve the licence I should be able to load the config from the disk1?
Thanks, sorry for the lengthy message.
BB
