ASA shared interface issue
  Hi Dears,
I configurate ASA in multiple context mode. I have two context.
C1 have 3 vlan in inside ( vlan id: 140.141,142)
C2 have 4 vlan inside  (vlan id: 40,41,,42)
Assign gigabitethernet0/0 both context for outside interface with same subnet but different ip.
C1 and C2 assign same physical interface for inside.- Interface gigabitethernet0/3
C1
allocate-interface Ethernet0/0 outside_C1
allocate-interface Ethernet0/0.3.140 inside_C1
allocate-interface Ethernet0/0.3.141 inside1_C1
allocate-interface Ethernet0/0.3.142 inside2_C1
config-url disk0:/c1
C2
allocate-interface Ethernet0/0 outside_C2
allocate-interface Ethernet0/0.3.40 outsdei_C2
allocate-interface Ethernet0/0.3.41 outsdei_C2
allocate-interface Ethernet0/0.3.42 outsdei_C2
C1 and C2 use same phycal interface but different  subinterface and ip address.
I write mac-adddress auto in system context.
the problem is.
when i do ping from c1 to c2  or from c2 to c1 vlan , only one vlan i can do ping.
In C1 i can ping (C2) vlan 40 ip address. can not ping vlan 41 and 42.
In C2 i can ping only (C1) vlan 140 subnet , i can not ping vlan 141 and 142.
ASA connenct to  core sw. In core sw i configurte vrf and dynamic routing protocol eigrp.also configurate eigrp in ASA.
is this ASA problems?
Is this routing problems?
Thanks.
355
