09-25-2005 07:48 PM - edited 02-21-2020 12:25 AM
Hi, with the ASA running in multiple mode, the 'system' space has config, yet has no ip address.
Just wondering what is the best way to back this particular config up.
I can backup all my contexts, but as this has no ip address it gets difficult.
09-25-2005 08:30 PM
If you do any of the "copy" commands from the system context off to an external FTP/TFTP server, it uses the IP addresses and routes configured on the admin context to get to that server. As long as your admin context has connectivity to the external server, then you can backup your config on the system context as well.
09-25-2005 08:37 PM
ah ok, thanks, that will work for manual, but what about for daily scheduled backups, e.g. I use catools from Kiwi......
