ASA USB Ports
Anyone knows what we can do with the usb ports that has the ASA. Are there for specific application or for future features?
Everyone's tags (3)
Hall of Fame Super Gold
ASA USB Ports
Like routers and switches, the USB ports are used to transfer files to-and-from the USB stick.
You can use the USB stick to copy the ASA FW IOS or move config in and out.  I, however, don't recommend you put a USB stick PERMANENTLY attached to the appliance.
Hall of Fame Super Silver
ASA USB Ports
In the new X-series of ASA, the USB replaces the old external Compact Flash (disk1:) function. Cisco advises it can be used for anything the internal CF card (disk0:) is used for - software images, configuration files, etc.
I would agree with Leo for the most part with the exception that as long as it wasn't the primary boot image I wouldn't have a hard time leaving one plugged in on a long term basis.
Best common practice would be to keep your internal disk0: from getting too cluttered and rely on it for all required boot- and run-time files.
6875
