ASA VPN Lan-toLan - Failover long distance - DR
Hi all!
I wonder if a solution is possible for failover lan-to-lan with the secondary (failover) on another website (long distance), using a switch to the solution between the primary and secondary.
Attachment topology as an example.
I Appreciate any help.
Re: ASA VPN Lan-toLan - Failover long distance - DR
Question - I presume that the DR is a seperate Internet routable IP address space?
Are the 2 sites serviced by the same ISP?
Hi Andrew!
Yes, the company is an IP address and DR is other IP.
The 2 sites are serviced by the same ISP.
Thank you.
Jose,
So the 2 sites have seperate IP addresses? If so what you are talking is about - is not possible.
The remote VPN clients will need to connect to another outside IP address in the event of failover, however AFAIK this cannot be a seperate IP range.
HTH>
217
