ASA with dedicated VPN interface thats on the same subnet as outside
I was wondering if this is possible or if there is another way around this.
Is it possible to configure the VPN feature on a different interface than the "outside" interface. I want users to connect to a different ip address and interface when connecting through VPN. My goal was to use an interface and name it "vpn" with a security level of 0. The ip address of the vpn interface would be on the same subnet as the outside. This is where I get a error message stating that the subnet overlaps the "outside" interface. Any help would be greatly appreciated.
Re: ASA with dedicated VPN interface thats on the same subnet as
Hi .. you can't allocate two IP addresses on the same range to two interfaces unless you want to use your firewall in transparent mode.
so you only have 2 options:
1.- get another public range and allocate it to one of the other interfaces. this interface will terminate the VPN connections.
2.- You could use one of the other interfaces.For example configure one of the interfaces with security level = 1 and address 192.168.1.11/24
and then create a static instruction
static (VPN_interface,outside) x.x.x.x 192.168.1.11 netmask 255.255.255.255
where x.x.x.x is a public address from the availble public range.
I hope it helps ... please rate it if it does !!!
Fernando thanks for the info. Would you recommend going with option 2 if we don't have another public range or just using the outside interface for incoming/outing and vpn traffic. Thanks for your advice.
263
