ASA5500 IPS ability Question
I've been tasked to impliment an IPS solution. I'm looking at the 4200 series appliances but at the same time I think I can squeeze in an ASA 5500 to replace my Pix 525.
Can I kill two birds with one ASA? Does the ASA's IPS version work as effectively as the 4200?
Re: ASA5500 IPS ability Question
I find it best to have seperate hardware. You can have the ASA do the job of the IPS just as effectively, but in my case I would rather have both. It is kind of a failover process I have right now. I can describe how I have mine setup if that will help you in your decision making.
Yes you can. If you use an ASA with an IPS module you will have the same result as with 2 devices. (5510 or up, 5505 is not modular)
127
