Community Member
ASA5505 VPN issue
Hi !
I am trying to setup VPN client using Anyconnect on a ASA5505 to allow access to remote worker to corporate network and Voice features.
Is SSL VPN the only way ?
Maybe i am going the wrong way.
Also I am limited to 2 conn. instead of 10 for IPsec.
basic:
ASA5505
outside PPPoE
inside (10.10.10.0/24) 10.10.10.2 to a Cisco 2801 Service router Fe0/0 (10.10.10.1).
2801 Router:
Fe0/1.20 Data 172.22.101.0
Fe0/1.100 Voice 172.22.100.0
ServiceEngine0 10.1.10.0
I also attached a copy of my running-config.
The issue i am having is when i connect using Anyconnect client, i am unable to access anything in my internal network and/or the internet.
Anybody can help ?
Thanks !
Community Member
Re: ASA5505 VPN issue
I got it !
Community Member
What did you have to do? I'm having a similiar issue...
Community Member
Switched to IPSec service instead of SSL, which seem to have a bug and keep the session alive even if the client is disconnected.
My Problem was, that I had a mis configured authentication's methods and a blocking inbound access rules.
128
