ASA5510 & ASA5520
I have a rather simple question ( I hope). We have several ASA5510s and 5520s in our enterprise and we are wondering if users SSL remote access is compatible with Windows Vista. Will also need to know what needs to be done to make them compatible and also if the users clients will need to be updated as well or not. The current code is listed below. Where might I be able to locate this in the future?
Boot microcode: CNlite-MC-Boot-Cisco-1.2
SSL/IKE
microcode: CNlite-MC-IPSEC-Admin-3.03
IPSec microcode: CNlite-MC-IPSECm-MAIN-2.04
Any information is greatly appreciated !!
Rick
Re: ASA5510 & ASA5520
Rick, if you are refering to Webvpn which is SSL based the answer to your question is yes SSL vpn is supported on Windows vista or that has an SSL enable browser.
See this link for more details on SSL RA
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00806ea271.shtml
Jorge
So the SSL will work with Vista users with out needing to update as long as the ASA code is 7.2 or higher?
Thanks again for your quick response, I have a heck of a time finding the necessary info on Cisco's site.
Yes it will, also the Annyconnect client is another solution for VPN client for VISTA OS as Cisco VPN client that regularly runs on XP or other Windows platforms other than vista is not supported under Vista OS.
AnnyConnect client is also SSL based.
Annyconnect client
http://www.cisco.com/en/US/docs/security/vpn_client/anyconnect/anyconnect20/release/notes/cvcrn200.html
Jorge
PLS rate any helpful posts if it helped
205
