ASA5510 Base License
Hy, I have ASA5510 Base License, what I must make to update the license Security Plus.
Re: ASA5510 Base License
To update the license you need to contact your local reseller and place a license upgrade order. They will provide you with a PAK for the order. Contact licensing@cisco.com with the PAK and the order details to get the license "activation key". Enter this activation-key on the ASA and reboot it.
-AJ
To upgrade to Security Plus license, you need to order the following:
Product no: ASA5510-SEC-PL=
Description: ASA 5510 Security Plus License w/ A/S HA, more VLANs + conns
http://www.cisco.com/en/US/products/ps6120/prod_brochure0900aecd80402e36.html
Depending on how you get your previous ASA box, your can either work with your reseller/vendor, or order from Cisco.
Rgds,
AK
OK, Thanks
282
